Discuss Replacing lead supply pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Simon Streeting
Hello, I am replacing a lead water pipe and wondered if it was necessary to have a stopcock outside the property like there is currently.
it is seised and about 50cm from the Thames water plastic stop valve.
i am of course planning to put a stopcock under the kitchen sink at the first junction
thanks in advance
Reply to Replacing lead supply pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My daughter's place has a small water leak on a ground floor radiator valve. The radiator pipework is small diameter.i.e 8 or 10 mm. A plumber is coming back in a day or so to make necessary repairs. I am a little concerned as the house has a Boilermate 2000 on the upper floor and the...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in kitchen only Stopcock in kitchen wall panel turns off cold water supply in kitchen only Red gate valve in airing cupboard next to bathroom turns off...
Hi there, Have bought an old house and am having the old lead water mains pipe replaced and a new stopcock location/piping installed after massively high readings from water testing by the water company. Also buying new plastic water tank to start afresh so to speak. Pipework/joinery looks to...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the cause. I would like a flow rate of about 12L/min. Here is my set-up: Standard gas boiler (not a combi) in the kitchen, have cold water tanks in the...
Essaboy
E
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
