Discuss Replacing Old Crane CH Control With Digital Control? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Having replaced all the radiators in current system I would like to update the control (as seen in image) with a modern digital one. Would this be a simple job and what type of control would I need?
I'm not a complete novice when it comes to electrics but then I'm no electrician either.
All help gratefully received.
https://i.*********/TzAO3NF.jpg
Shouldn't be too hard depending on what's behind
Drayton lifestyle is a decent prog
The "Crane" timer allows hot water on its own (options 1 - 3) but not heating on its own - HW has to be on at the same time (options 4 - 6).
This says that the system is a "pumped heating, gravity hot water" one. So any programmer you purchase must have a "gravity" option.
This type of system is no longer permitted, but upgrading to a "fully pumped" system is not compulsory. However you should consider it as it will save money in the long run.
Reply to Replacing Old Crane CH Control With Digital Control? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
