Discuss Roman Bathtub tap identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I need to have one of my taps replaced(on far left) due to a slow leak and calcification at the base rings and handle, but I have no idea what brand/make the fittings are as they have no markings on them.
Even if somebody could find a needle in a haystack and identify that set I doubt if you could buy one tap alone.
Might be better and quicker to replace the complete set, Google 5 hole bath taps, prices vary from 3 digits to 4 digits though.
Try grohe, or Hans grohe.
But could be crosswater, or lefroy brooks.
Thanks for the info on possible brands. I will have to cut through the tiles in order to gain access to the pipes as the bath was installed without an access panel.
might be easier to remove the bath to gain access ?
If you find the manufacturer, it might be possible to replace the insert and rings from above
It IS possible to replace from above.
The alternative is £1200 ish for retiling and bath out. #SeeItAllTheTime
Reply to Roman Bathtub tap identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
