Discuss Room stat with combi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In theory no, as long as you have TRV's on all but one radiator. Regulations say that all new systems installed have a room stat fitted.
Reply to Room stat with combi? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
