Discuss Rothenberger plasticut waste cutter or pipe shears? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have always used to pipe shears that you squeeze down and twist the pipe to cut. However I am thinking of buying the rothenberger plasticut waste cutters. What do people find the best?
Very good I use the Roth pipe slices
As above they are much better and easier to use. Just remember to put the guard back on
You use the shears on solvent waste ?
Best choice I've made for plastic pipes. The plastic cutters are very very good, clean cuts, safes times.
The slices are good
I got a full set from screwfix
I have the rocut shears they are ace, clean straight cut & blade is still sharp. Well worth the money & time saved over hacksaw. A colleague had the slice which came into its own in a tight space
Shears probably edge it due to fitting in the box, not having to carry round the set of slices
100% roth slice set, all three sizes in a kit. Precise straight cuts and you can get in tight spots and chop out. A bit hard to turn on certain pipes and watch your fingers on the blade. I think others have already said keep the blade guard in place. Expensive but really anice addition to tools.
Reply to Rothenberger plasticut waste cutter or pipe shears? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
