Discuss Salus IT500 Wireless Thermostat Wiring Help Needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I need advice on which wires go where, i have a Drayton lifestyle programmer for hot water and central heating and I am trying to fit a Salus IT500 wireless thermostat. I need to know how to wire this up.
picture attached show current setup,
L to live
N to neutral
Link live to com
4 to ch no
3 to aux no
1 to aux nc
Hope this helps
When you turn the heating on does the port valve move at all
Also pump should come on if boiler comes on as there wired together
  1. Hi Shaun,
    no, the port valve stays in the same position, no movement,
    boiler fired up and hot water working all ok, but the central heating will not fire up, its as if no signal or feed there.
hi shaun,
i have put the old set up back on until after xmas day,
if its all right when you, can i touch base with you then for some more help on this
Did you install both links like in your pic ?
Hi Shaun
I have just rewired as instructed, central heating working all ok, no concerns, but the hot water will not fire up, when I put the central heating on the valve go to the right and stays there even if I try and fire up the hot water, the only way I can get the valve to move back is if I disconnect the white wire. picture attached to the current wiring
Is the cylinder stat holding it off ?? Eg upto temp ?
Hi Shaun,
could be, the tank is hot from this morning and I haven't used any water.
I will programme the app for hot water and central heating times and see if it works then.
central heating great, thanks for the quick reply, will let you know.
Shaun
Reply to Salus IT500 Wireless Thermostat Wiring Help Needed in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
