Discuss salus rf stat wiring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
eddiebrown424
Hi
I am fitting a vaillant ecotecc pro 30 and have been asked to put in a salus missalrt 300rf stat and receiver. I normally wire the boiler into a 3 mp fused spur. Can anyone tell me the wiring for this stat and boiler and if its best to go into a 3 mp fused spur and out to the receiver. I found this link and was wondering if it is right
http://www.***********/diy/threads/how-to-wire-salus-rt500rf-to-valiant-eco-pro-tec.383770/
Thanks in advance
Eddie
Reply to salus rf stat wiring in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have an all Vaillant setup - an EcoTEC Plus 637 system boiler plus wired VR720 and VR92 SensoCOMFORT controller, driving two CH zones plus DHW. It all works, but unfortunately we have found that the room stats are poorly located, and so the level of control is not what it should be. We had...
Hi, I am trying to link a Hive heating & hot water dual channel receiver to an old Vaillant THERMOcompact VU GB 242/1 E system boiler. It has an internal programmer that is similar to a time switch 120 (plug in seven day programmer) This programmer is connect to a terminal strip using 345 (three...
Hi all,new to the forum and hoping to get some guidance through the boiler minefield . We moved into a 70s bungalow last Feb,its got a Greensted 241 junior mark 3. The expansion tank has failed, also it has a Boss therm sender unit wired to it but the previous owner didn't leave the receiver...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed function, it'll switch off at the programmer (no light) but boiler will stay on until they turn the stat down, I went and looked at it, they said they...
2K
Good morning all I hope you are all well? I am after a bit of advice please, I am looking to fit a Drayton LWC1 wiring centre into my boiler circuit as the wiring is incorrect, someone has linked the Neutral and HW off wires in the programmer circuit for some reason. Looking at the wiring...
2K
