Discuss Sanicompact not flushing correctly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi there, had a sanicompact installed for a year now, with no issues. But lately, it has been making a different noise when flushing, and doesnt remove the toilet paper on the first flush. Any help or advice would be appreciated. Thanks
RPM is definitely the man to ask.
But he doesn't come on the forum as frequently anymore.
Pathetic responce time pal , I think he “plays out” on Thursday nights lol .
:D think we need to send the search party out
Reply to Sanicompact not flushing correctly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there I fitted a Sanicompact 43 about10 years ago. A few years ago i noticed that it would intermittently activate in the middle of the night so I fitted a simple pull cord swith to turn it off at night About a month ago I recently had a blockage so pulled it apart and cleaned everything...
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a month ago. The last couple of times it was used, it made a loud noise and acted like it didn't want to flush. I guessed that it might be time to...
Hi there. I have a Cersanit close coupled toilet which as started leaking between the cistern and the bowl when flushed. I've taken the cistern off and this is what I see. I'm assuming the issue is with the silicon gasket (please see attached photos) but can't seem to find a replacement...
Had a quote for a new boiler installation. Quote said... Power Flush require and install new boiler, ==== After the boiler was started, it was making horrible noises == I mentioned this and sent an audio recording to the company. ==== Said that is normal boiler noise even though it shakes the...
Hello! I was checking something in the toilet cistern. I flushed, but holding the float ball, so the cistern wouldn't be filled. With a very low level of water in the cistern, I flushed a couple of times. Then I let go of the float ball and the cistern was filled. I didn't do or change...
