Discuss scrapping elson tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
billybob150811
if anyone does sheet lead work and wants some sheet copper to tin I am scrapping an elson tank and they can have the sheet copper for scrap price
Typical, my pals wants one for his arty-farty type sister , shes after making something it would have been ideal ... To far away !
Reply to scrapping elson tank in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I've had a burst pipe under bathroom floor. Ive had it dug up and made safe with the affected pipe cut and end caps fitted. The pipes are cover with a plastic sheet and then screet on top. I called out my gas boiler cover to make a permanent repair. The company they sent out have said it is...
Hi, I have a fairly modern multifuel stove with a back boiler connected to a Elson Sapphire double feed indirect hot water tank and I need to drain down the system to move a radiator. Would anyone be able to offer any advice as to the correct drain down and refill procedure for this tank as...
This unit is located in France where they use diesel not kerosene. The feed from the underground tank is not getting through to the boiler. The boiler works fine if I connect the hoses up to a remote tank of diesel. I am assuming that a filter is blocked somewhere but there is nothing between...
I have an Elson Sapphire double feed indirect hot water tank and I need to drain down the system to move some radiators. Would anyone be able to offer any advice as to the correct drain down and refill procedure for this tank? It is a self contained boxed and insulated unit with a single cold...
1K
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element required). This means that I have a 2.5 year old StainlessLITE Plus Horizontal unvented mains pressure 204L cylinder left over. We had it installed in Jan...
Peter M
