Discuss Sealing Back to Wall Pan in the Sanitary Ware area at UKPlumbersForums.co.uk.
Tags:
  1. elj221c
    elj221c New Member
    The Boss wants me to seal the sides and top of the pan against the WC cabinet. Obviously I will seal around the base but I think sides and top will look rubbish.
    What do others think?
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR
    I always seal them that way mate.
    • Agree Agree x 2
  3. ShaunCorbs
    White silicon and just fill in any gaps etc
    • Agree Agree x 2
  4. rpm
    rpm Trusted Plumber
    What is the largest gap size, see some that are way out from the cabinet panel and they do look carp when silicone is applied.
    • Agree Agree x 1
  5. Harvest Fields
    Never had one more than 5/8 mm that said. I have been told I have been lucky.
  6. elj221c
    elj221c New Member
    My gaps are pretty small but down the sides at least the ceramic curves in towards the WC cabinet so that my Fugi won't help.
    However, I'd best give it a go for the sake of domestic harmony!
    Thanks for the input.
  7. ShaunCorbs
    Just use the 90 profile to fill in the ceramic curve
    • Agree Agree x 1
  8. elj221c
    elj221c New Member
    Just came to that conclusion with a dry run.
    Ta.
  9. ShaunCorbs
    Silicon spray helps with anything if the tool grips too much
    • Agree Agree x 1
  10. YorkshireDave
    YorkshireDave Plumber
    I just use a credit card!! Honest. Bank don't like it tho :D
  11. ShaunCorbs
    You may laugh but needs must lolly pop stick works as well :D
    • Funny Funny x 1
  12. Matchless.plumb
    Matchless.plumb Trusted Plumber GSR
    Will agree with above 5-8mm line will look need and acts as strengthener.
  13. Moffski72
    Moffski72 Moffski72 GSR
    Just spray it wit soapy water then use whatever device u like to remove excess silicone...Lidl do some really good silicone tools...
  14. townfanjon
    townfanjon Trusted Plumber GSR
    I used to , dont anymore , looks *****
Loading...
Similar Threads - Sealing Wall Forum Date
Free uHeat 2018 World Cup Wall Chart (Win A Tablet!) Plumbers Cafe May 24, 2018
Leaking shower pod/wall hung shower unit Plumbing Forum May 22, 2018
