Discuss sealing shower tiles in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. jimplumb
    jimplumb New Member
    just tiled wet room tray/former with very small mosaic tiles, will i need to apply a sealer before use? my concern is the grouting, used mapei flexible.
  2. townfanjon
    If they are porcelain or ceramic you will be ok with flex grout, I hope they are not Travertine , they definitely have to be sealed prior to grouting .
    • Agree Agree x 1
  3. Matchless.plumb
    Matchless.plumb Trusted Plumber
    Hi Jim,
    The Stone tile or tile with a porous surface needs to be sealed before grouting otherwise the grout bonds to the stone and sticks and is hard to get it off.
    Id better Seal after it is installed. The grout lines are really what needs to be sealed the most that's my opinion.
    Basically you will need to seal for the stone ones twice before and after.
  4. Chalked
    Chalked Plumber GSR
    What type/ make of try former is it?
    If it's a natural stone, slate or travatine mosaic, if needs sealing before grouting and again after. If it's a porcelain, or glass mosaic, it won't. But I find sealing the grout helps with keeping the grout lines clean.
    • Like Like x 1
  5. jimplumb
    jimplumb New Member
  6. jimplumb
    jimplumb New Member
    Hello everyone, thanks for the advice.
    The tray former is Abacus Elements and the mosaics are about 15mm square glass and porcelain so a lot of grout just thought sealing would give more protection, any advice on sealer appreciated.
  7. Chalked
    Chalked Plumber GSR
    Abacus trays have a minimum of 50mm tiles, to prevent point loading
    They can compress into the tray former
    • Agree Agree x 1
  8. jimplumb
    jimplumb New Member
    oops too late now they are already in and grouted.
Loading...
Similar Threads - sealing shower tiles Forum Date
Hot water pump for shower advice Bathrooms, Showers and Wetrooms Yesterday at 3:25 PM
Is it best to buy a shower tray from the same maker as the enclosure.Will it be a better fit? Plumbing Forum Thursday at 11:30 AM
