Discuss Sealing Washer Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello all,
I'm looking for a nylon sealing washer.
It measures 11mm inner diamteter, 1.4mm in thickness. Does anybody know where I can get hold of one of these? I just can't find it.
Reply to Sealing Washer Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe using compression: https://www.NoLinkingToThis/p/flomasta-compression-straight-tap-connector-15mm-x-1-2-/58294 If not, please could someone let me know...
Hi. Water is slowly leaking into the toilet bowl from the cistern. I suspect that it's the rubber washer at the bottom of the tube that's the problem but I can't figure out how to get to it. I can feel it when I put my hand down to the bottom of the tube and it seems flexible but it's 16 years...
I removed an old shower hose, which was installed by previous home owner at least 12 years ago. Upon removal, the connection is like nothing I have ever seen and I am unable to find any replacement hose of similar connector type. btw: When I removed the hose , there was no loose rubber washer...
Hello, Have had a leak on my UFH manifold. Originally incorrectly diagnosed as being the nuts/washer to the pump, it now looks like it's coming from this thermostatic valve. Have tried googling "ufh thermostatic valve" and none of them look like this or have connectors like this (guessing part...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so far. I replaced the cartridge. Leak persisted. Bought some replacement seals and tried to put in place of the old ones. Here's what I did next. Remove...
