H
how2
[FONT=&]Hi Guys.[/FONT]
[FONT=&]Need some Help. Ideal Logic combi 24[/FONT]
[FONT=&]CH works but no DHW,[/FONT][FONT=&] the guy told me to use "one shot" which I found to be drain cleaner(91% sulphuric Acid). [/FONT]
[FONT=&]I have put Sentinel X400 into the heating system and will also use X100.[/FONT]
[FONT=&]How will I know which is the CH holes and which are the DHW holes?[/FONT]
[FONT=&]Which holes will have black deposits? - CH assumption[/FONT]
[FONT=&]Which holes will have Limescale? - DHW assumption[/FONT]
[FONT=&]I am assuming the DHW is blocked.[/FONT]
[FONT=&]I have access to a wide range of acids which should I use and for how long?[/FONT]
[FONT=&]Are any of these not Acids suitable fro the secondary heat exchange?[/FONT]
[FONT=&]Should i use Fernox DS3 which is about 90% or more [/FONT]Sulphamic acid
Citric acid,
Hydrochloric acid
Sulphuric acid
Sulphamic acid
Thank you
Citric acid,
Hydrochloric acid
Sulphuric acid
Sulphamic acid
Thank you
