Discuss Shower hose too small for wall fitting in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Yorkie23
    Yorkie23 New Member
    I currently have a shower with an aerator attached at the wall fixings. I have just bought a new shower head with an integral aerator, so no longer need the original one. However, when I remove it, the shower hose (standard fit) no longer fits as the aerator tapers from 2cm diameter to 1.5cm. What can I use to replace the aerator to make the hose fit?
    Thank you
  2. rpm
    rpm Trusted Plumber Top Contributor!!
    Edited out.
  3. Chalked
    Chalked Plumber GSR
    Undo the next bit, still attached to the valve. Hat will leave a 1/2 thread
    • Agree Agree x 1
    • Winner Winner x 1
  4. Yorkie23
    Yorkie23 New Member
    Thank you, knew there would be a simple solution. It had got stuck on and I didn’t want to get the pliers onto it and damage it if it wasn’t supposed to come off!
Loading...
Similar Threads - Shower hose small Forum Date
Cable to an electric shower Plumbers Arms Sep 17, 2018
Looking for mixer taps with shower attachment unusual size. Valves & Taps Sep 16, 2018
