Discuss Shower mixer identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi my first time of posting.
Can anyone help please.
I have a shower mixer that is approx 10 yrs old. Photo attached.
I want to redo the bathroom but I cannot see how to take it off.
I feel if I had a manufacturers name I might be able to find the information on the internet.
Can anyone help with a manufacturer and any other information.
Thanks in advance.
josh.
If nobody here can identify it then try the shower doc with the same photo Josh.
Hi Josh. Not sure but most built in valves come apart the same way by either removing the outer flange / chrome cover which gives u access to the screws or pull the handle off ( straight out ) which will reveal something. Have a go as if your replacing it then it's not like u need to be gentle lol......
Thank you kris and rpm.
I actually would like to reuse the mixer. We have good water pressure and it works well without the complications of a thermostatic mixer.
On the centre of the temperature control is a capital T made up of a double line of dots if that is any help.
rpm. How do I find the shower doc.
Thanks for your help to both.
josh.
Reply to Shower mixer identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Please help me obtain a copy of the user manual for this bath and shower mixer, pictured below. I am particularly concerned about how to re-regulate the bath filler so it fills the bath to the desired level. Many thanks!
We have a pumped shower with a thermostatically controlled mixer valve. My wife complains that when she is having a long shower (hair wash etc) the shower runs at the right temperature for much of the time but suddenly changes to run cold, usually during the hair rinse time, for no apparent...
Hi has anyone ever renew a thermostatic shower cartridge on a Firedearth shower in photo I’m trying to find replacement Firedearth will tell me the manufacturer of mixer
hi all i hope you are all well i'm planning to install my shower mixer on Saturday. today i was doing a dry fit and i wanted to show you some photos and questions. i'm using fast fixing brackets. i was wondering what length do i cut the pipe to? also my shower bar mixer has these cone shaped...
I recently had a plumber come over to look at a badly leaking shower head. As best I can recall, he described the problem as a crack in the bridge of the cold water pipe and explained that there were two options: 1. Get into the wall with a jackhammer to fix the problem; or 2. Install one of...
