Discuss Shower not getting hot water. in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. jay90
    jay90 New Member
    Hi. I have a normal shower and an overhead rain shower that are all connected through one unit with two handles on the wall to switch between showers. A relative took a shower and instead of turning the unit on the wall off they just turned both taps up to stop water coming out of any shower. I turned the unit off a couple of hours later. Anyhow now when I switch on the shower it is only cold water running and will not give hot water out. Can anybody think what is wrong? Thankyou.
  2. Chuck
    Chuck Active Member
    Can you upload a couple of photographs showing the shower unit and these handles, please?
    What do you mean by "turned up" exactly? Fully clockwise or anticlockwise?
    How do you normally operate the shower?
  3. jay90
    jay90 New Member
    To operate the shower you press the on off switch. There are two handles on the wall to switch between showers. Both handles when turned outwards allow both showers to operate. When turned back up pointing to the ceiling turns both showers off.
  4. Chuck
    Chuck Active Member
    So, you're saying that your guest left the system with no water flowing and but the shower unit 'on'.
    Depending on the model of shower unit and type of installation this could be (a) fine, (b) cause a themal safey cut-out to trip, (c) caused failure of the heating unit.
    We can rule out (a), which is what should have happened for a correctly installed and operating shower. Options (b) and (c) require a competent person to fix. You should also get them to review the installation to make sure it complies with the manufacturer's installation instructions.
    Of course, the fault could just have occured by coincidence around the time you had a guest.
  5. jay90
    jay90 New Member
    Would that be the thermostat? So is it nothing serious or costly?
  6. Matchless.plumb
    Matchless.plumb Trusted Plumber
    Do you have a couple of pictures ?
  7. jay90
    jay90 New Member
    No I am. It in at the minute.
  8. JCplumb
    JCplumb Plumber
    OP mentions on/off switch which suggests an electric shower, but I doubt any electric shower could operate a riser head and a rainfall head.
    Is this an electric shower?
    If it's a mixer (not electric) then what hot water system do you have? Is there a pump?
  9. jay90
    jay90 New Member
    Yes t is an electric shower.
Loading...
Similar Threads - Shower getting water Forum Date
Mixer shower not getting hot Bathrooms, Showers and Wetrooms Dec 17, 2017
Hot water pump for shower advice Bathrooms, Showers and Wetrooms Yesterday at 3:25 PM
