Discuss shower pump connection in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Eddm87
    Eddm87 New Member
    Hi all.
    Pretty sure this must have been asked plenty of times but...
    I am installing new shower pump. A little bit confused as to how to connect to cylinder.
    I can put a 45 degree from the offtake on the cylinder and tee into it, if I do this, do I need a swept tee angled up the vent pipe?
    The other option is Essex or Surrey. Essex I have to drill the tank, prefer not to if possible.
    Surrey seems plausible. Is it easy to install? Also is there a reduced flow as it is obviously a restriction in the fitting.
    I am running 22mm up to the pump connections.
    I think i read somewhere 22mm is pants in a Surrey flange, only use if using 15mm
    Advice appreciated.
    Edd
  2. townfanjon
    Flange is best , but you can buy a connection thats fits directly on to the top of the cylinder , somebody will be along shortly with link no doubt
Loading...
Similar Threads - shower pump connection Forum Date
advice please: my plumber connected combi boiler to a shower pump Plumbing Forum Friday at 2:39 PM
recurring airlock in hot water feed to shower pump Bathrooms, Showers and Wetrooms Thursday at 8:37 PM
