Discuss Shower pump type. in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. wirepuller
    wirepuller New Member
    Hi to the forum.
    Hands up I'm a sparks from the electricians forum but would like to tackle this myself so advise would be much appreciated.
    I've bought an Aqualisa Midas 110s mixer valve, not installed yet, but have realized with a head of only 700mm I'm going to need a pump for it to work.
    My question is will a positive head pump work ok with the mixer valve and the <0.1 bar gravity head....will there be enough flow to activate the flow switch?
    Or should I buy a universal...(more expensive) pump which apparently will work regardless of flow?
    I'm only looking at a 1-2 bar pump, don't want a deluge or my teen daughter will empty the hot tank 4 times a day.
    Thanks for any help.
  2. ShaunCorbs
    Afternoon
    As long as your shower head is below the bottom of the cold water tank by 0.5m
    Positive head is fine if it's less negative/ universe (these sense the pressure loss and not the flow)
    Cold water tank needs to be around 50 gallon (220l)
    • Like Like x 1
  3. townfanjon
    townfanjon Trusted Plumber GSR
    Personally I would go universal mate. 1.5 bar pump , showers dont forget are more about flow than pressure
    • Like Like x 2
  4. wirepuller
    Conflicting opinions..!
    Not sure now....I guess a universal would be a cert as opposed to a positive head pump which should be ok?
  5. Matchless.plumb
    Matchless.plumb Trusted Plumber
    I agree to above universal shower pump perhaps of the good ones Stuart Turner monsoon
    • Like Like x 1
  6. wirepuller
    Thanks all.
  7. ShaunCorbs
  8. king of pipes
    I use salamander pumps they have a new web site have a look at www.salamanderpumps.co.uk very reliable and very quiet regards kop
    • Like Like x 1
  9. king of pipes
    There you go screen sot of the menu page cheers kop
    • Like Like x 1
  10. wirepuller
    A great help chaps. Many thanks.
    Was looking at the salamander pumps which seem less costly that the ST ones.
    • Agree Agree x 1
Loading...
Similar Threads - Shower pump type Forum Date
Shower pump feed off 15mm secondary return? Gas Safe Registered Plumbers Only Dec 29, 2017
Determining cold feed and shower pump criteria Bathrooms, Showers and Wetrooms Nov 14, 2017
