  1. Hi, welcome to the new look UKPlumbersForums.co.uk - Login with your usual login details, or sign up if you don't already have an account. If you post just once, all the advertisements get automatically removed. We have some competitions coming soon, and lots of new feaures.
Discuss Shower valve height? in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. macka09
    macka09 Plumber GSR
    Hi all. When first fixing for a shower valve what sort of height do you bring them out off the floor? Also what height do you a deluge head?
  2. goz666
    goz666 GSR
    Ask the customer, I did one last year and asked the woman of the house, she went and got her husband who was 6'4" and he said well we have three lads... two at 6'7" and the youngest who is 6'8" and still growing so put it a bit higher if you can.
  3. mikeygas
    mikeygas Plumber GSR
    I find if you have a shower valve fitted over the bath then 1300mm off the floor is a good height.
    If valve is over a shower tray/in a cubicle then around 1m from top of shower tray.
  4. Chalked
    Chalked Plumber GSR
    1.2m from the tray for me.
  5. JCplumb
    JCplumb Plumber
    Just be careful if it's a fixed riser/head type. Some guy I did a job with once realised the riser was too long and hit the ceiling after fixing the mixer and the tiler had done his bit ;)
  6. Allgoode
    Allgoode GSR
    Follow M.I. if there are any or as a rough guide work out the tray installation height allowing for up stands or if tray straight onto floor surface add around 1 - 1.2m from where you would stand in tray (just above waist height).
    For shower head speak to customer if on rail as mentioned above, if deluge head there should be some M.I. for that but take into account if a shower enclosure the height of the enclosure.
    I think average height in UK is between 5'8" - 5'10" so need sufficient clearance above that and also to not have any splashing going over enclosure/cubicle top when in the shower especially if it has a high operating pressure when in use.
  7. Chriswareham
    Chriswareham GSR
    i would fitt about 1200 to 1300mm high try to work out the tiling so that it fulls within the centure of a tile or on a grout line . it looks so much better same with the head
Loading...
Similar Threads - Shower valve height Forum Date
Exposed thermastic shower valve 2mm inlet Plumbing Forum Aug 15, 2017
Do I need isolating valves on every electric shower in a new build? Bathrooms, Showers and Wetrooms Aug 9, 2017
Shower/Mixer tap diverter valve issue. New Member Introductions Jul 19, 2017
Single handle thermostatic shower valve Bathrooms, Showers and Wetrooms May 25, 2017
Identification of Shower Mixer Valve - For Servicing Bathrooms, Showers and Wetrooms May 25, 2017
Bristan Qube Dual Control Thermostatic Recessed Shower Valve Bathrooms, Showers and Wetrooms May 23, 2017
Bristan 1901 Recessed Thermostatic Dual Control Chrome Shower Valve N2 SHCVO C flow valve not closin Valves & Taps May 2, 2017
