Discuss Showermate issues after swapping old for new in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, just wondering if anyone has some advice!
Changed a showermate pump in the week, old one was a 1.4 twin but apparently this isnt made anymore so i swapped with a 1.8 twin.
The issue is now the shower pump kicks in on hot only. As i get further round to cold the pump stops. Ive read the old shower pump needed a minimum of 0.5bar inlet whereas this new 1.8 pump needs a minimum of 0.8bar. Could this be the issue or am i missing something else more obvious? All pipework etc is exisiting, i just changed hoses and pump.
Sods law it went on the hottest week of the year when customer wants a cooler shower as at any other time this issuue wouldnt of been noticed!
Is there aa boosting pump i can put on my cold suppy from the tank to increase that pressure upto 0.8bar.
Should add its a gravity system, tank in loft and cylinder in airing cupboard.
Thanks in advance
The 1.8 requires 0.8 litres per minute flow, not 0.8 bar pressure.
I'd be looking for a restriction in the cold feed, for example if the isolating valve in the flexible input hose is not fully open.
its not the shower is it ? , also have you checked the shower strainers ?
You will see upload a file next to post reply
Click upload a file
Find the picture
Click and upload
Ok thankyou
Reply to Showermate issues after swapping old for new in the Plumbing Jobs | The Job-board area at PlumbersForums.net
