Discuss Shutting off hot and cold water. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey guys....changing shower in the basement of a 4 story house...i think hot water is off a gravity fed hot water cylinder and the heating is off a boiler..... to shut off the water supply I switched off the mains coming into the house, turned off the boiler(just switch at front no valves), 2 red valves next to cylinder. It took ages for the water to stop and had to drain the whole system before the taps stopped running.....anything i can shut off to stop water flow straight away or are the valves probably faulty next to the cylinder?( 1 valve said cold feed and the other was unmarked, there was also a valve next to the HWC that had no knob(...Tks...
If pipes to shower are exposed ! freeze pipes cut in full bore service valve, save all the hassle of draining system and possibility of air locks when refilling + the amount of time it saves, remember both H & C need to be fed from roof tanks.
You will need to empty the header tank in the loft anyway, to fit a cold water supply for the shower pump. So just turn off the incoming water main and run off all water.
Think he is just replacing a old unit could be some service valves somewhere.
Just be careful creating a vacuum on your hot water as this could collapse the hot cylinder.
Good point Best, should have mentioned to only bung on a cold system with all heating off. I sometimes forget that we do it routinely and assume that a regular person would know this. My bad...
No worries Darren. I routinely bung heating systems, but have become a bit paranoid about any vented copper cylinders or unvented units being under suction. I nearly did a lot of damage to a copper cylinder once when bunging the vent.
Also witnessed a new copper cylinder gradually crushing in when pipes in attic were frozen and hot tap on floor below was opened.
Reply to Shutting off hot and cold water. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
