Discuss Silicone seal on shower tray aqua panels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0029
When installing aqua panels on a shower is it advisorable to leave a small gap 1-2mm between the tray and the bottom of the aqua panel to allow some silicon in to the joint or put the panels tight sitting on the tray and silicone over?
I leave a 3mm gap and sit them down on plastic packers on the tray , some manufacturers like you to silicone and sit them in a trim but looks pony , 6mm bead of sanitary silicone and smoothed off with a fugi tool job done . cheers kop
Why is it advisorable to leave a gap? Does the silicone hold better if it has a small void to fill?
Dow corning 785 is what i use it seals the edge of the panel i only use multi panel with marine ply backing dont use this method on a MDF backed panel stick to manufacturers instructions. Kop
Reply to Silicone seal on shower tray aqua panels in the Plumbing Jobs | The Job-board area at PlumbersForums.net
