Discuss Simple schematic diagrams in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone advise an easy to use software package for producing simple plumbing schematic diagrams in hospitals/large sites. We have floor plans and want to draw the schematic over the floor plan.
I've done basic schematics and wiring diagrams in Word of all things - you can make it show gridlines on the page then insert shapes (which includes lines, arrows, all sorts of symbols).
I don't know how you would overlay that on to the existing floor plans though..
tracing paper then scan :)
Reply to Simple schematic diagrams in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I'm plumbing my campervan and made the following schematic to show the different modes it can operate. Although I'm an experienced DIYer, I've never tackled a plumbing job this complicated and I'd appreciate any advice. Normal operation using Tank 1 – B, F open Normal operation using Tank 2 –...
Deleted member 129220
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction with concrete slab subfloor. All of the waste pipes run in the concrete, and exit the property at the chamber as pictured, just outside the building...
My living room smells like a sewer but I can't tell where it is coming from. Not sure where to start looking. The saniflo discharge pipe runs above but there is no sign of leakage on the ceiling. The main drain run from the manhole at the back runs under the kitchen, which has a solid floor...
I am looking into a new Main eco compact / Baxi 618 system boiler set up for PDHW (if its possible) I was hoping to use the EPH controls priority hot water pack I currently have a 15year old HWC around 900mm tall by 450mm dia would I benefit from a new fast recovery HWC for the system (I...
Hi everyone, Just wanted to share my experience with "upgrading" an S plan setup to Opentherm and Vaillant Control Center (VR66). There are a few threads on a few different forums but I wanted to share a full write-up with all the steps needed, benefits and costs. Overall, I fully recommend...
1K
