Discuss Single flow kitchen sink mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If fitting a kitchen sink tap(single flow) were the water mixes in the tap body. If mains cold and gravity fed hot water. Do I need to put single check valves on both the hot and cold supply's to the sink?
just the hot supply, but i would be surprised if you got much hot out of the tap on blend (hot and cold)
best would be change the tape for a separate type (doesnt mix in the body)
Thank you yes IL see about changing the tap. Can imagine the check valve will make the hot water flow poor. Does the cold definitely not need a check valve then?
that would be the best solution
and yes it would reduce it by about 1/4
and no as the hot wouldn't flow up the cold as its more pressure
And with a dual flow one check valves aren't needed, as the water doesn't mix in the tap?
Thats is resulting in better flow from the hot but be careful you don't get one that mixes in the spout
What happens if mains water supply is cut off? Wouldn't the hot water flow back into it and contaminate?
Only if the tap is opened can't see why you open the cold side when it was shut off abd run hot water
Reply to Single flow kitchen sink mixer tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, I need to replace the kitchen tap, all my neighbours have two single taps in their kitchen and bathroom whereas I have a single lever tap in the bathroom and kitchen. Due to living in a flat and having a shared water supply I was advised to get a dual flow tap for the kitchen so...
I live in an apartment block where generally hot water is supplied from the communal hot water cylinder and cold water to bathrooms is supplied from cold water tanks in the loft. It is a vented system. However, in a basement flat and a ground floor flat cold water supply to bathrooms is...
Hi there, All was good until one day the hot water suddenly started running quite a lot cooler. Putting my hand on the output at the boiler it's still hot there so I'm guessing there's a problem with cold water feeding into the hot water somewhere along the line. I have mixer taps on two...
Hello, I have a few mixer taps to install in bathrooms and kitchen. The kitchen tap also has a wondering spray arm capability. On researching something else, i stumbled across people saying that a check valve should be placed on the cold mains feed. How can I tell if the mixer taps/spray arm mix...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which I and other residents in the building share as we have shared supply to bathrooms and kitchens) Under kitchen sink stop valve turns off cold water in...
