Discuss Slight drip brown water from nut / bleed valve area? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, we have 2 rads. where there is slight rusting visible around the silver nut around the bleed nipple. water is coming out but evaporates to leave a brown stain. Can I tighten nut...or will this need replacing? Do I need our usual plumber..or diy? thanks.
Sounds like the o ring has failed easy enough to do diy
Turn both rad valves off
Get a container and bleed rad until it stops
Take a plug out with a old towel below to catch any drips
Either replace the o ring or add some ptfe to the threads
Tighten the plug back in
And do the same for the air bleed
Close bleed screw if you haven't already done
Open both valves
Bleed rad
Check for leaks
Reply to Slight drip brown water from nut / bleed valve area? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Sticky
