Discuss Slow flow DHW from Worcester Bosch Greenstar 28i Junior Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I've got a 7 year old Worcester Bosch Greenstar 28i combi boiler, the dhw flow rate has gradually got slower over time and is now only about 4 litres a minute, the water is consistently hot all the time just slow flowing, all the hot water taps in the house run at the same pace, cold flow is good pressure everywhere, any ideas would be appreciated.
If your in a hard water area it's more than likely a partial blockage in the plate heat exchanger a engineer will be needed to replace this and solve your problem . Kop
Reply to Slow flow DHW from Worcester Bosch Greenstar 28i Junior Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud clicking/knocking sound that lasts about a minute, stops for 20-30 seconds and starts again. It seems to happen at night, starting in the evening...
Morning all, I have a Worcester Bosch 8000 life 40kw boiler on system with 7 radiators and the boiler is located in the loft of a 1907 end of terrace house. It has been range rated down to 50% and I currently have the flow temperature set to 64, due to slow warm up. I recently purchased a...
I have a Worcester Bosch Greenstar 15i condenser boiler which is about 13 years old. There is a separate hot water tank. Recently the fan in the boiler has started to stay on all the time. My usual engineer took a look at it and advised me to contact the manufacturer. I then had an engineer from...
Hi there, My boiler (Worcester Greenstar Ri) has started making a soft knocking noise when it turns on, and again a few times when it turns off. I've attached a short video of the sound. It isn't constant, it seems to happen within the first 10 mins of the boiler starting up, then you won't...
Simon from Watford
