Discuss Small leak at bottom of radiator (see photo) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi!
My girlfriend has just sent me the attached photo .There is a small dripping leak from the small stubby sticking out bit below a radiator. Enough for the pressure to drop a it (boiler repressurised). She said the end was hand loose so tightened it. The radiator is not a slimline type and has no bleeding valves etc. at the top as far as I can see. What is this small stubby pipe ...and why should it suddenly develop a leak? (the wiring below is for old cctv and not live!)...THANKS.
It's a Drain-Off Valve used to drain down the system. Just need to tighten it more or drain down and change the washer in there
ok thanks ....she has tightened it a bit....is the washer in there rubber or metal?...and if it needs replacing is a drain down (or freezing the pipes either side) the only 2 options?...thanks
Yep a little rubber washer , there is a way it maybe able to be done live , but unless you know how to do it that way , you will be safer draining down .
ok thanks...I thought I might be lucky and have a stopcock or the like nearby...so as to do only a partial drain?
probably wouldn't have to do a complete drain down, as it is pressurised you should only need to knock the pressure off.
Thanks all....leak now stopped....the square spigot was finger loose so it has been tightened and the leak has stopped....cheers!
Have a look on inside edge of radiator for bleed screw it may have a white plastic cap over it .
Reply to Small leak at bottom of radiator (see photo) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be making things worse. I really need another expert's opinion, to put my mind at rest, or help me make the decision to stop using his services. I...
3K
Hi all, We recently purchased a house and nothing seems to work correctly here, I've spent weeks rectifying issues. Plumbing, electrical, carpentry it's been never ending. The house was built by Barratt Homes in the year 2000, it is a 3 bedroom house called a Palmerston, the CH/HW system is a Y...
5K
Hi, new to this forum. I hope someone experienced out there can help me find the fix. We recently finished a building project and had a major re-design/move of all of our hot water (megaflo), boiler and central heating system. I am not a plumber nor do I know much about plumbing but I know...
2K
Hi everyone, About a year ago we moved into a new property which has a towel heater as part of the Central Heating System. There are no thermostats as part of the valves, so after a quick look on google I believe it is a manual heater. In the summer a leak developed on the left hand side...
1K
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming through the bedroom wall from the bathroom on the other side of the wall. The shower is over the bath and the bathroom walls are tiled around three sides of...
2K
