Discuss Smart Control of Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a Worcester Bosch Greenstar Heatslave II oil fired boiler and would like to fit a smart control system. Can anyone recommend the best one to use (e.g. Hive, Nest etc.). Thanks in advance
You can fit (or have fitted) whatever turns you on. Do your research and take your pick. Some do some things and some do some more. They all work from your phone but it depends how much you want someone or some machine tracking your movements.
A so called smart controller is no different to a light switch electrically.
Reply to Smart Control of Oil Boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an issue with a Worcester Greenstar 29CDi Classic boiler. I replaced the old thermostat controller with a smart dual-channel HIVE one. I did all the wiring following the diagram in the attached picture. The boiler doesn't work anymore. Please, any suggestions?
We have recently moved into a property which has a Worcester Greenstar Highflow 440 Standalone Combi gas boiler. This appears to be a relatively old unit however, it is still in great working condition and has been serviced on a regular basis. I'd like to add a Nest Thermostat to control the...
Hi, I was hoping to replace an old system boiler with a Vaillant Ecotec Exclusive 627 system boiler, thats the one with the diverter valve so no need for zone valves, controling it with a V-Smart and a VR10. I've spoken to Vaillant Tech and they said you cannot use the VR10 with a vented...
Afternoon all, I have a customer with a heavily extended semi which now has 4 beds, 2 bathroom and 5 reception rooms. They have started working from home and want to zone the heating system, unfortunately the system boiler and cylinder is in the garage with 2 x 22mm primary pipes disappearing...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
