Brooksie
Can anyone help please!
Recently fiished installing a bathroom suit in the upstaires of a house but the customer says she can smell a poo type smell when lying in the bath. Unfortunately I can't smell the problem but her son says he too can smell it!
I used a flexi poo discharge pipe for the first time to link the toilet to the 110 mm discharge connection sticking out of the floor.
The toilet is a low level one with concealed cistern (which was a pig to fit) in a vanity type cabinet.
The bath has a compact trap (19 mm seal), the sink has a standard 32 mm p trap and the WC''s trap is built in
The main discharge pipe runs below the floor boards and the sink and bath wastes discharge vertically into this 110 mm pipe as it runs off to the main soil stack the far end of the neighbouring en-suit. There is very little fall on this pipe.
Is there a way of testing the system for air leakage from above the floorboards?
Are flexi poo pipes renound for splitting or malfuncyioning?
Is there a way of further sealing up where the 110 mm flexi joint meets the rigid 110 mm pipe connection.
Help and advise would be most appreciated.
Thanks in advance
Brooksie
Thanks in advance
Brooksie
