Discuss Solvent weld pipe into compression stand pipe fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Getting a Mcalpine washing machine standpipe, it has a compression fitting. Will solvent weld pipe fit in this, i hear that some pipes are larger than others. Floplast pipe if that makes any difference.
Yes will be fine be 11/2 pipe
Reply to Solvent weld pipe into compression stand pipe fitting in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hello all, Iā€™m replacing a concrete paving slab patio in the back yard. The original patio used 50mm deep concrete slabs on hardcore & sand. Iā€™m planning to pour a 100mm deep concrete patio on 100mm hardcore. In order to achieve the same final height to line up with the rest of the patio, I...
