R
realstokebloke
lots of great advice ref additional CW tank installation, thanks.
But, the 22mm tank connectors say they require a 36mm hole in the wall of the tank for the fitting.
I can find plenty of 35mm or 38mm but no 36mm.
Is it crucial, or is it a case of using a 35mm & 'helping' it in? (obviously, i want the hole to be as neat & clean as possible.)
What does anyone else use plse?
Also, is it just a 'normal' hole cutter - not a specific one for plastic tanks?
Also (ii) is there a preferred way to block unwanted holes in the tank? I have been told a new speedfit with a plug (by Speedfit obviously :wink: ) or, if there are compressions on there already, just fit some pipe in & solder on a copper stop end?
Thanks.
Thanks.
