Discuss Stanton premier unvented hot water system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi folks, Im have an issue with our hot water tank. At random times there is a really loud clunk/bang coming from the water tank upstairs, its hard to put any pattern to this. Its arguably got worse over the summer but this has been going on for about 10 months. I'm guessing its possibly a valve or something not doing its job.
Any ideas would be appreciated??
Thanks in advance
Reply to Stanton premier unvented hot water system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We moved into a new property yesterday and are a little baffled by the heating/water tank situation. The previous owners unhelpfully left any kind of instructions/manual and therefore trying to figure out ourselves. We have what looks like a boiler/water tank system (coming from a standard...
Hello, I am fitting new taps and a shower mixer in my en-suite and was looking to isolate the hot water pipes. I have an unvented indirect heating system (have attached some photos). I was wondering if the isolation valve that would shut off the water to the hot water taps is as circled in the...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
