Discuss starting an emergency lear repair service in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I have just registered with this site...I am mainly a kitchen/bathroom installer but carry out most home renovations and have been doing so for the last 20 odd years. I am located in north London and am thinking of focussing on a call out emergency service aimed at north London. I already have some key equipment ie rofrost freezer kit. I just wondered if anyone has experience with call out's....the pitfalls...charge rates, key tools/equipment needed, tips and tricks etc etc... any info would be welcome.....
cheers...
First will you be doing this yourself ? or contracting to a larger Co ? if for yourself when do you intend to sleep ? you will need to keep a large amount of parts on board, and you will be competing with some large Co, Then it comes down to charges ! look at the large Co they always take payment up front, and you will need very good insurance cover .
theres a leak on boiler, cylinder, stopcock! what do you do?
will you just be tofo'ing them as first response?
Customers love to have their leak fixed today without using the word "emergency"
I'd say the hardest thing is getting enough work. Being an emergency plumber you can't arrange 10 jobs for next week you need 1 job every 2 hours for 10 hours and they just don't come like that. You can't book any work in advance because then you can't respond to an emergency. Very tricky
That's why dedicated emergency call out firms are so expensive. You have to make your money from less jobs.
The other problem is money.
Expect customers to say that they aren't paying the £60 or whatever you quoted as you've only been there 2 minutes and fixed it.
The fact you've driven 30 miles round trip and it's 2 o'clock in the morning and you've saved their a** means nothing to them.
Reply to starting an emergency lear repair service in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey, forum friends! 👋 Excited to introduce Master Drain Ltd, your go-to expert for top-notch drain installation and repair services. Here's what sets us apart: 🔧 Seamless Installation: When it comes to drain installation, precision is key. Our skilled team at Master Drain Ltd ensures that your...
We have just moved in to a 1934 Semi- and I am getting round a few simple DIY tasks, including a couple of plumbing-part renewals such as modern pipe/u-bend/fittings to kitchen sink, rinse sink etc as preventative maintenance! Nothing complex or specialist, that's for you expert guys! But in...
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to replace, says National Gas chief Jonathan Leake14 January 2024 • 5:49pm Mr Butterworth, chief executive of National Gas, says the network is powered by...
Current boiler Worcester Greenstar 30CDi installed Aug 2011. Started showing error EA. Initially a rest made it work again but last Thursday it would reset but then showed the same error after a few minutes. No heating (only problem is heated towel rail does not heat) but also no hot water. Then...
I have a contract with HomeServe to supply "emergency" plumbing service should I ever have a problem. Recently I was clearing out the gutters using a plastic yogurt-pot-type-thing to scoop out the crud. Unfortunately, this pot fell down the soak-away pipe that the gutters drain in to. I called...
2K
