Discuss Steam from condensate drain in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Mr Fog
    Mr Fog New Member
    Hi
    I am having my kitchen revamped and have removed the sink and waste pipes.
    However the condensate drain pipe was connected to the waste pipe so I therfore temporarily dropped the condensate drain into a bucket.
    I have since turned on the boiler so my wife could take a shower and noticed water vapour/steam coming from the condensate drain pipe...
    Is this normal or a problem with the boiler which is an Isar Ideal HE24.
    Many thanks in advance for any repies.
    Mr Fog
  2. ShaunCorbs
    Don't run the boiler into a bucket with the isar series the condense isn't trapped so needs a trap inline, normally just below the boiler / under the kitchen worktop
    It's basically what's going out the flue in the condense pipe so it's products of combustion
    Best option is enlist the services of a gas safe engy to put the condense right and maybe service the boiler
  3. Chuck
    Chuck Active Member
    Yes, it's a problem. If this "vapour/steam" is being emitted into your house so, probably, is flue gas. Turn off the boiler and get a Gas Safe engineer to come and sort it out for you.
    Broadly speaking, a condensate drain needs to be treated with as much respect as the flue. Don't mess with it or you may end up with a dead family.
  4. Mr Fog
    Mr Fog New Member
    Thank you for the replies chaps, I'll get it looked at.
  5. heliotrope
    heliotrope Plumber GSR
    So are you saying the Isar does not have an S Trap fitted?
  6. ShaunCorbs
    Nope straight from the combustion chamber
  7. Chuck
    Chuck Active Member
  8. ShaunCorbs
    If there's an internal trap why is an external to the boiler trap required
    It's prob just in case the condense line gets blocked, like on the solos
  9. Chuck
    Chuck Active Member
    You seem to have found another version of the ISAR HE 24 than I did. The manual I cited is dated Aug 2009 and does not show an external trap. Anyway, the symptoms certainly suggest no trap (likely) or an empty trap (less likely) and either way I hope we can agree that the OP should stop using the boiler until the condensate drain has been reviewed and reconnected properly by a GSR.
    [I've edited my original comment appropriately.]
  10. ShaunCorbs
    2008 mine so one year apart
    And tbh think there's no trap
    As on hot water the trap should of filled / stopped steaming / venting poc to the room within 10-15 mins
    • Agree Agree x 1
  11. king of pipes
    king of pipes Trusted Plumber GSR Top Contributor!!
    Thats a bit of a no no Mr Fog products of combustion with be escaping into your kitchen get it reconnected temporarily until your revamp
    • Agree Agree x 1
  12. Mr Fog
    Mr Fog New Member
    Thanks for all your replies folks, I appreciate your help.
    Mr Fog
  13. Gasmk1
    Gasmk1 GSR
    Before mounting the boiler on the wall, the condensate drain (provided in the h/ware pack) must be connected from the boiler ‘S’ trap to a drainage point, preferably within the building.
    Ensure that the condensate trap is full of water before commissioning the boiler . Refer to Frame 26.
    from the instructions it hought all isars had this difficult to remove and prone to blocking s trap fitted
  14. ShaunCorbs
    Is that from the 2008 / earlier instructions??
  15. Gasmk1
    Gasmk1 GSR
    march 08
  16. garygvl
    garygvl New Member
    there's always been s traps on isars
Loading...
Similar Threads - Steam condensate drain Forum Date
Condensate Piping decisions Gas Safe Register Forum - Public Forum Jul 26, 2017
