Discuss Steel pipe size identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
i need to cap this pipe under the floor, will need to remove the elbow and fit a cap. Not sure what size the pipe is. 1/2 inch??
looks 1/2 should measure 3/4 od
3/4 should measure 1" od
could be 3/8
i use steel pipe for non plumbing uses (industrial decor) that looks like 3/8 if you can take a photo against a rule i check against the sizes i have in stock looks too small for half inch not trying to sell just give advise ive got all sizes of black pressure pipe in my workshop so will be able to give a definite answer
It does look like 3/8" to me but it is always difficult to tell off a photo.
Normally the O.D. of steel measure roughly the next size up to what it is. There and thereabouts. Or if you look at a fitting on the steel it may say the size on one side.
Reply to Steel pipe size identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
