Discuss Strange problem - mains water running for 10 secs every few mins in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Adam Jenkins
    Adam Jenkins New Member
    Got a strange issue and hoping someone has some ideas please.
    The other day I needed to switch off the stopcock to work on my toilet. Water was off for an hour or so and since then there is a strange noise every few minutes. It sounds like water running in a pipe and is coming from the same area under the sink as the stopcock. Also in the upstairs airing cupboard I can feel the water pumping through one of the pipes (think it's a cold water mains pipe but not sure).
    I have a combi boiler so nothing going on with a loft tank. Tried turing the boiler off just in case it was related (it's not) and have also bled radiators (there was a fair bit of air in the system).
    The only thing that stops this intermittent issue is turning the stopcock off again.
    Any ideas? thanks in advance!
  2. scott_d
    scott_d Plumber GSR
    Toilet filling
    It may be overflowing internally
    • Agree Agree x 2
  3. Adam Jenkins
    Hi - thanks but it's not any of the toilets, I checked them. As I say the sound is coming from near the stopcock - the toilets are silent and are not running (well one of them does run a bit sometimes but that's just the inner plug not always sealing properly after a flush - just flushing again solves it) and they are not overfilling...
    • Dislike Dislike x 1
  4. Jim Goodenough
    Jim Goodenough Plumber
    Are you sure you have a sealed system, very rare but it could be the ball-valve opening on F&E tank if it's an open vented system?
  5. jtsplumbing
    jtsplumbing Plumber GSR
    Pin hole in plate heat exchanger.
  6. Adam Jenkins
    Found the problem and it WAS one of the toilets running that was to blame (sorry Scott_d)!!
    The plug is leaking just a little bit and the water level is only dropping a tiny amount which is why I didn't notice it.
    Thanks a lot for the advice!
    • Like Like x 1
Loading...
Similar Threads - Strange problem mains Forum Date
strange fault with baxi solo 2 Central Heating Forum Aug 12, 2018
Drayton LP241 timers in a strange state Plumbing Forum Aug 5, 2018
