Discuss Strange water flow in taps in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. jaffeling
    jaffeling New Member
    I don't know why the water flow became so strange in taps, when I turn the taps on and off back and forth, the flow will became stronger, but every time i need to do it again after turned off the taps :(
    To all pros, any idea?
    Thank you!
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Cartridge need aligning mate. Easy enough job if you are confident enough. But make sure you turn off the hot and cold water.
  3. Ric2013
    Ric2013 Plumber
    I'm glad Harvest gets it as I thought it was a 'non-rising spindle' type mechanism with worn O rings in need of lubrication, or with water leaking past the o ring making it difficult to turn on... until I saw you turn it anticlockwise and it again stopped running. Not seen that before!
    • Like Like x 1
  4. peter0504030201
    peter0504030201 New Member
    common problem with taps valves , build up of corrosion / no grease inside, its like metal on metal better to replace the valves with theses
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Flomasta Threaded Tap Glands 24mm x ½" 2 Pack (3279F)
    View reviews (40)
    [​IMG]
    View all Q&A
    8mm spline. Threaded tap glands to fit most ½" taps. Suitable for taps that require a threaded collar.
    More Info View all Flomasta Brassware Sundries
  5. Harvest Fields
    How on earth do you know that cartridge will fit that tap. ????
    • Agree Agree x 1
  6. peter0504030201
    its not cartridge its a tap spline , this valve will fit most taps , I'm a plumber I know what I'm looking at , I do these jobs all the time
  7. Harvest Fields
    Understood. But aren’t all splines different and not all heads fit on to them?
    • Agree Agree x 1
  8. peter0504030201
    that's right mate , there are loads of different valves , the amount of teeth , valve dimensions . but there are a lot of taps that take standard valves, I got 5 different types of ceramic valves an tap splines on my van an they do most taps if not just change the taps an get some scrap
    • Funny Funny x 1
    • Optimistic Optimistic x 1
  9. ShaunCorbs
    :D made a new friend have we
    • Funny Funny x 1
  10. ShaunCorbs
    op tbh best to change the set of taps easier in the long run and could be cheaper than trying to find the right insert/insides
    • Disagree Disagree x 1
  11. Harvest Fields
    You know me too well mate.;);)
  12. peter0504030201
    that old chestnut:D
    • Funny Funny x 1
  13. Harvest Fields
    I have aligned them before mate and they have lasted another 12 months before having to change them. But if the OP wants piece of mind then you may be right.
    • Agree Agree x 1
  14. ShaunCorbs
    yep unless there branded and dont just need a washer and re seat then i change the taps
    been to a few 6 months - a year later and the taps failed again normally change them the same as fitting new cartridges as sometimes its quicker so it just costs them the taps extra etc
    • Like Like x 1
  15. Best
    Best Trusted Plumber
    When you say " aligned " - do you mean taking the spindle apart and putting it tight together again?
    I discovered the reason why the works come apart and simply greasing them won't usually be a long term fix. It is the lower O ring seal that wears and allows water to pass into the internals. That is why the hot tap is usually the first to give trouble
    • Agree Agree x 1
    • Informative Informative x 1
Loading...
Similar Threads - Strange water flow Forum Date
Noisy combi boiler strange repair option Central Heating Forum Apr 27, 2018
Wc water level is to high in the bowl New Member Introductions Monday at 3:17 PM
