Discuss Strange wet patch underneath radiator... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good morning all,
First ever post on this forum :)
Recently moved into a ground floor flat and have had an absolute nightmare of a time since. Had to fork out a large sum of money within 3 weeks of moving in on a brand new boiler. However, this was not the solution to my problems.
Essentially the new boiler has a digital pressure gauge on the front and it seems to lose 0.1-0.2 mbar each day since it was installed on Tuesday. The old boiler also did this.
I've gone round to check my rads (I have 7 in total inside the flat) and checked for leaks and couldn't spot anything. I have a large radiator covering the living room/dining room and I noticed that the carpet under the left edge of the radiator was very damp. There are no drips that I can see coming from that end of the radiator either. The carpet also had a strange greasy/oily feel to it.
The radiator is attached to an outside facing wall. I've checked the length of the carpet against that wall and there were no other damp patches other than the patch I found underneath the radiator.
Could this be the culprit? Really nervous about this :(
Yes it probably is , the seam will be rusted or the the rad pin holed this will leak when under pressure isolate that rad and see if your boiler holds pressure put a container where the damp patch is to see what is collected cheers kop
Yes and turn the lockshied valve off on the other end you will need a a small adjustable to do this pull the white cap off to reveal the stem cheers kop
Well nothing was collected after I ran the heating for an hour. I've left a container underneath the radiator.
If the new boiler is losing 0.1-0.2 mbar a day, how much water are we talking about here?
A cup full if that bud thats the beauty of sealed systems they contain on average 100 + litres so the boiler will shut down below .5 bar if it leaks and you know theres a problem , get your plumber back to replace the rad cheers kop
We don't know that the radiator itself is leaking yet though. It could just as easily be a pin holed pipe under the rad spraying a tiny jet of water up at the underside of the floor. Isolating that rad completely as you suggested to eliminate it from our enquiries is great advice though.
Hes already done that bud and run the heating for a hour and no leak ????? Its in his last post Cheers kop
Reply to Strange wet patch underneath radiator... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, we've just had someone round to fit lino in our toilet. He ripped up the old lino only to reveal a large wet patch around the toilet (see photo). The floor is damp to touch and I'm left wondering what could be the cause of this? Given the shape of the damp patch, would it likely be a leaking...
1K
Oil boiler (now~15 years old) unvented system with 17 radiators. We moved in 5 years ago and I had to keep bleeding the same radiator. The bleed gas could be burned with a blue flame and the water was acidic (pH 5.5). Since then system has been chemically flushed (it was not too bad) and the...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that has previously been extended. In one of the bedrooms that has been extended there are 2 radiators, one which looks like it was fitted when the...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small 3rd floor flat, I have a radiator in the front room and one in the hall (very close to each other), there is a drainage valve on one of these. My back...
I'll start this by saying I'm hoping to sort this by diy / minimal professional help as I'm a very tight budget! I've got a walk-in shower in a wet room. The shower has a tiled-over former with an additional ring of tiles around it. When the shower's in use, a drip comes through into the room...
