Discuss Stuart Turner 3bar Single Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Reply to Stuart Turner 3bar Single Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Are specialist refurbished Stuart Turner pumps reliable, or is it a bit of a gamble. Would it be best to buy new and pay twice as much.
I have a negative head twin impeller Stuart Turner pump feeding hot and cold to three showers, one bath, plus hot to three basin's from my gravity fed, loft cold water tank and airing cupboard hot water tank. Occasionally the pump operates for a couple of seconds without demand for water. More...
We have a Stuart Turner Monsoon 2 bar shower pump which has lately been either refusing to start, or not switching off when we turn off the shower. Tapping the side of the outlet pipe seems to unstick it more often than not, but it's a real nuisance. We have an oil-fired Aga, and the water does...
5K
Joandfran
J
Hi All I have a Grundfos Amazon SSP 3 bar positive head pump fitted, pumping domestic hot water. Its always been on the noisy side, been in for about 10 years. I had been thinking about changing it for a Stuart Turner Monsoon 3.0 Single which is more expensive. Is it a better quality pump, will...
4K
I just had a quote for a new boiler install as follows I dont undertand why a 15-60 boiler pump is needed and a 25-100 pump is needed as well I currently have an ideal mexico 2 heat only boiler - It has one DAB pump on the boiler return and a 2 port valve at the flow pipe to allow for heating...
