Discuss Stuart Turner boost pump problem in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. eagleeye
    eagleeye Member
    A customer of mine has recently had trouble with a Stuart Turner Monsoon twin positive 3 bar pump. After going backwards and forwards with pump assist and a few parts later I finally got the pump working again. Now every now and it won't turn off. After a few attempts I finally got in touch with an approved Stuart Turner engineer who tells me it's most probably because the hot water is over 70 degrees which has deformed the brass that holds the magnetic.
    Can anyone tell me if this is possible or if they have ever had it
  2. ShaunCorbs
    What is the hot water temp ?
  3. eagleeye
    eagleeye Member
    Not checked it as yet but as its not got a cylinder stat on the hot water cylinder most probably somewhere near boiler temp. And as that is up on max most probably well over 70
  4. ShaunCorbs
    Gravity hot water system (heating) ??
  5. eagleeye
    eagleeye Member
    No fully pumped. Boiler is a potterton suprima
  6. ShaunCorbs
    Should have a cylinder stat
    Any port valves / type of system
  7. SimonG
    SimonG Trusted Plumber
    Might have a pipe stat on cylinder return.
Loading...
Similar Threads - Stuart Turner boost Forum Date
Stuart Turner pump is slow? Plumbing Forum Nov 23, 2017
  1. allintext:EagleEye
