Discuss System boiler to install with Megaflo Eco Slimline: Baxi or Worcester Bosch? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
MaidenheadChris
Hi there - can anyone make a recommendation as to whether I should go with a Worcester Bosch or Baxi system boiler when installing a Megaflo hot water cylinder? This is a full house renovation and the owner wants to use an iBoost (from their new solar PV) with the tank.
Any experiences (good or bad) with either? Let me know!!!
Both are very good but I'm a Worcester man myself but it's down to either what the customer wants price wise or what you normally install / happy with
Glad we're all different, this world would be very boring and dull if we wernt
In my own home I have a recently-installed Worcester system boiler and Megaflo Eco cylinder (no PVs) in an S-plan+ setup. There's one issue that may only be obvious with hindsight.
For the Megaflo to get up to the recommended 60°C so its thermostat stops demanding heat the flow temperature of the boiler needs to be set to a minimum of 65°C. This means for the boiler to be in condensing mode you need to get the temperature difference between flow and return of at least 12°C and preferably a touch more.
I live in the SW and for a good fraction of the year 65°C is a bit warm to get optimal perfomance from the CH even with conventional radiators. I imagine that UFH, which I don't have installed, would benefit from it being even lower.
Worcester does have a boiler controller ('Wave' IIRC) that allows the CH and HW temperatures to be set independently, but according to its docs it requires thst you have the optional internal divertor valve kit installed, which gives you a Y-Plan base system. This limitation is a bit frustrating as in an ideal world I'd want the hot water to heat up to 60°C in the night, say with 70°C flow and then the rest of the time have the flow temperature for the CH much lower. (I prefer S-plan to Y-plan.)
In practice the current system althought not 'theoretically ideal' is nice and simple and works well.
I am a Vaillant man myself. Don't know much about solar. But I'm sure that Vaillant do a boiler that can cope with what you require. Have a look at them and see what you think.
How do the economics of that work? I pay six or seven times as much for electricity as I do for gas. I'd have thought it makes more sense to export electricity and use the money from the generation and export tariffs to buy gas?
Reply to System boiler to install with Megaflo Eco Slimline: Baxi or Worcester Bosch? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi everyone a local installer has recently quoted me £3,660 for a complete install using the main eco compact 25kw boiler i have also been waiting for more feedback and reviews of the new worcester bosch 1000 which seems to be getting quite positive initial feedback, and a few criticisms which...
2K
Deleted member 131795
Hi. I’m new here and due to have a new boiler fitted. Does anyone have recommendations or thoughts on either the Worcester 8000 40KW Combi or the Baxi 40kw Platinum or the Valliant EcoTec Plus 838. The Worcester is the most costly but I’m happy to pay more if it means a better boiler (long term...
Hi All, We have finally decided after a bit of a persuasion to have installed a utility room in our garage that currently houses our oil boiler. Initially we thought the boiler may stay in place but after discussions with the builder we would have to move the boiler to replace the floor and...
I need a little help if possible as I am trying to check that my current system is running efficiently but not really sure how to check, sorry if this is a long one and I have tried to contact a Honeywell connected specialist but they dont seem interested unless installing a new system and the...
2K
We are experiencing an issue with CH short cycling on a Worcester Bosch Greenstar 25i ErP boiler. From a cold start the boiler fires for only ~25 seconds before exceeding the set CH flow temperature and entering it's 3 minute short cycle programme. As soon as the short cycle programme kicks in...
1K
