Discuss Tap connectors (and other things) diameter and BSP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi....I'm not a plumber but have fitted a few taps and waste water pipes. Even though I've done that, I get confused when I look at the Screwfix catalogue that say for example "Flexible Tap Connectors".
They give the following...
"Dia - 15mm, BSP 3/8 " and
"Dia - 15mm, BSP 1/2 "
I think the BSP means British Standard Pipe and 3/8" is 19 TPI whereas 1/2" is 14 TPI, is that correct?
What difference does this make if I'm connecting a wash hand basin to 15mm copper feed pipe?
15mm x 3/8" flexi is simply 15mm one end (compression or push fit) for onto a pipe and a 3/8" nut at the other end for onto a 3/8" fill valve, for example.
Although I wouldn't use any of them tbh, as not needed.
BSP is British Standard pipe thread.
The difference you need to look for in flex hoses is that some are smaller bore than others and will effect flow rate depending on the pressure.
If that makes any sense.
Most German taps are 3/8 threaded grohe etc
Thank you for your prompt responses. Is it the case then that (for example) on a wash hand basin that has a 15 mm cw feed, I can buy a tap that has a 1/2" BSP thread or a I can buy a tap that has a 3/8" BSP thread?
Most taps are 1/2 unless they say
You could buy a tap that has either will still work the same
Engineer - thanks, I'm nearly understanding all this now. You say
"You could buy a tap that has either will still work the same". Does that mean if I buy a tap with a 3/8 thread I could use a 15 mm x 1/2 tap connector? That would confuse me if it's correct.
No you would need a 3/8-15mm flexi
Best - you say you wouldn't use any of them, why is that?
Don't really need to. I just use a pipe bender on copper pipe.
It will outlast a flexi.
I don't like weak links in plumbing and just replace any jobs I come across with copper, like if repairing a toilet, or replacing a tap or fill valve.
A flexi is normally only a rubber hose with some outer metal braiding.
I only work with them if they are part of monobloc taps.
Reply to Tap connectors (and other things) diameter and BSP in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, basic question. I have a leaking kitchen tap. I'm a bit confused on the part I need to get. On Screwfix I can see "Flomasta 1/2 inch BSP quarter turn ceramic tap glands" - are these the right parts? But I can also see 8x8mm 20-tooth spines, 9x9mm 20-Tooth Spines and others - which of these...
Hi I'm going to be fitting a tap like this one: And just wanted to check that this is the correct part for connecting to 15mm copper pipe using compression: https://www.NoLinkingToThis/p/flomasta-compression-straight-tap-connector-15mm-x-1-2-/58294 If not, please could someone let me know...
Hello, I have a troublesome fixed 15mm copper pipe with isolation valve going to my toilet fill valve. It's too tight for a Flexi hose. Can I use a push fit tap connector instead which will give me more flexibility in fitting?
I am trying to source adaptors/reducers for the below taps for my renocation We have the tap ware currently but Union adaptors are needed to fit the Australian copper pipe sizes of ½ and ¾ Can anyone suggest where to get these? Thank you in advance Antony Tap 1 From the USA - has a 3/8 pt...
Deleted member 120897
Hi I am trying to replace my bathroom tap with a new one, I am trying to remove the existing rusty flexible tap connectors from this bit of 22mm copper pipe. But this thing is not budging at all its like its welded or super glued on, I am using some water pliers on both points here but its not...
