Discuss Tap fitting in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
Tags:
  1. gcharlt
    gcharlt New Member
    Sure this is an easy one for you guys !! bought this fountain tap kit and when they arrived this is all I received, can anyone point me in the right direction as to what I need in fittings and how these are fitted to a breeze block wall?
    Thanx in advance. 20170425_060601.jpg 20170425_060750.jpg 20170425_060601.jpg 20170425_060750.jpg 20170425_060601.jpg 20170425_060750.jpg 20170425_060601.jpg 20170425_060750.jpg
  2. Keefy
    Keefy Plumber
    Hard to see what you've actually got from those pictures, maybe another picture showing the whole thing will help.
    Where did you buy it from?
  3. gcharlt
    gcharlt New Member
    Hi thanx for the reply.
    Attached a couple more photos
    Bought from online retailer but they are ignoring my requests for fitting instructions.
  4. gcharlt
    gcharlt New Member
  5. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Probably because they have no idea either:p
  6. ShaunCorbs
    The spout female back plate
    As for the mixer male irons and fixe the pipes good as there the only thing holding the valve
  7. gcharlt
    gcharlt New Member
    Brilliant thank you!!!
  8. Harvest Fields
    I have not seen one like that before. New to me also.
  9. ShaunCorbs
    Depending on how thick / the depth from the back plate to the spout you may need a new longer brass nipple (easy to get hold of)
  10. gcharlt
    gcharlt New Member
    Just my luck, will take to merchants tomorrow and try and sort
Loading...
Similar Threads - fitting Forum Date
Best place for end feed or capillary fittings Plumbing Forum Jan 6, 2018
Toilet inlet not fully closing at fitting new diaphram Plumbing Forum Jan 5, 2018
