Discuss Thermostatic Blending Valve Identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
Can anybody identify this Thermostatic Blending Valve from my Underfloor heating ?
It seems to be stuck on full temp and not mixing the cold flow.
Sorry.
Looking at your photo, the flow/return and mixed are different.!
It will still work, with a bit of modification to the pipework.
Sorry.
Yes, just noticed the dimensions are different. I really want a straight swap out, so dimensions are critical.
The other option is that I try taking it apart and cleaning it out.
Has anybody had good success in taking blending valves apart and cleaning them up ? Any tips ?
Reply to Thermostatic Blending Valve Identification in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have I blend valve from Nu-Heat ( they bought it from Reliance, as per attached spec). I have dismantled the valve now 3 times and replaced it with new components from Nu-Heat but the valve is not working properly. The valve replacement seems very simple with 4 main components and some...
Customer wants an outside tap for dog washing so needs to be blended. The hot water is gravity and its a bungalow so little head at the point of installation. I can't get a cold from the storage cistern to the utility so it has to be mains cold. Can pressure reducing valves be taken down to...
1K
I have a heating system comprised of skirting radiators that form part of a loop from the boiler, round the house and back. Some rooms get warmer than others despite closing off the skirting radiator heat vent. They are designed to house the finned heating pipe and a return pipe, the latter...
the majority of my radiators have thermostatic valves. Some of these work fine but some of them dont let you adjust the temp. ie. Setting one or setting 5 makes no difference - the radiator is blazing hot. For small bedrooms this is pain cos the room just heats up too much. we first...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
