Discuss thermostatic valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
big al
having only recently completed C&G level 2, i have been asked to replace 6 valves on rads to thermostatic type. If i bung feed and expansion tank i know i can work on the system without having to drain it all one at a time. My query is wether i have to fill each rad seperatley and bleed it or can i change all valves and bleed them all after?
Plug the cistern (water conservation - water regs :) )
Drain from the lowest point and crack on. Remember to add your inhibitor when refilling :)
ok thanks
Thank you for your help
Reply to thermostatic valves in the Plumbing Jobs | The Job-board area at PlumbersForums.net
