Discuss Thermosyphon loop with a boiler stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a multi-fuel boiler stove heating a 600l tank with an internal coil using a thermosyphon. The problem is that when the stove cools the thermosyphon reverses, the stove becomes a radiator and I loose my hot water.
I have installed a n/r valve (flap, not spring) but it reduces the flow rate to the extent that the water boils in the stove.
Can anyone suggest a way to prevent the thermosyphon reversing but still allow unrestricted foreword flow?
Hi Alan
This is not my area of expertise but it sound like you might be able to alter the pipework on the return from the store to the boiler so that you form a anti-siphons loop i.e. the pipe drops down some distance below the connection level into the boiler then comes back up & connecting.
Shoot me down in flames someone.
Hi Alan
Thanks for that input Chris, The outlet from the storage tank and the inlet to the stove are both about 350mm above a concrete floor so no possibility of a vertical loop. My first attempt to solve this problem was to make a loop in the inlet to the tank (see attachment). It didn't prevent reverse thermosyphon. Do you think it might work if I extended the loop much lower. In theory the hot water in the tank should not be able to flow downwards, but it does manage to flow down about a foot when flow reverses.
Sorry Chris, I'm new to this.. I thought I attached a photo, but I don't see it.
I click on "upload a file" select "camera" , take a shot and click "OK". Where am I going wrong?
Click upload file, select the file, click okay and wait for it to upload then click insert into post.
It depends on your device as to how to find the file.
That safety blow off needs connecting up as well
Reply to Thermosyphon loop with a boiler stove in the Plumbing Jobs | The Job-board area at PlumbersForums.net
