Discuss Thoughts on career changes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
simlaboy
Hi all ,
Getting to an age where installs are very hard work , been a CORGI / Gas Safe engineer since 1992 , need any ideas on changing to something else in the industry. Tried servicing and breakdown work , found it very boring and stressful ( the driving mainly ) . Anybody with advice on this ? Would be greatly appreciated
Hi all ,
Hi simlaboy,
Welcome to the forum,
Why not trying to get a job as a gas safe tutor? It might be not as easy but perhaps with some more qualifications you could teach other people and giving your knowledge further.
What about standing for parliament ? could do with someone with common sense to run the country
Welcome, hope you find something better suited for you soon :)
Reply to Thoughts on career changes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone. I'm currently working on a job for a customer. their radiators are not all heating up. in total there is 12 radiators. 4 of these are on 15mm pipework, the rest are on 10mm. its powered by a Grundfos ups3 pump. the boiler is an 18kw heat only boiler. There are two radiators mainly...
I currently have a Vaillant ecoTEC Plus 438 system boiler which is 13 years old. I have been having problems with the boiler which potentially boils down to the heat exchanger so I am now looking to bite the bullet and have a new boiler installed. My set up at home is that I have a 4-bed...
Hi I need some advice as this has been ongoing since august and nobody can find a problem but meantime water is damaging my walls. The lady upstairs had a plumber in July who relocated her washbasin shower and fitted a new radiator.He caused a bad leak and came to fix it in august and I thought...
Hi Everyone, For those who like a long read but I could rally do with some advice. Might be a bit long this. For background. A gardener/landscaping friend of mine is going to install an irrigation system in a customer's garden. He asked me to pop around and measure the pressures and flowrates...
Evening all. Can anyone help me with a bit of advice. We “inherited“ a Potterton Prima 60F boiler (which we were told in 2013 was 3/4 years old). It turns out after checking Serial number with Potterton that it was manufactured in 2003. Had it regularly serviced but a few weeks ago it failed...
Deleted member 120897
