Discuss Thoughts on jointing compound for compression fittings? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Compression joints on heating systems are subject to positive and negative pressures. Jointing paste helps the friction between, so aiding the tightening. Also helps air being drawn in at microscopic level, when under negative pressure.
It's an added form of joint security.
@Best
Is the dislike real, or just bug thumbs
That was bad text on my part. I meant that paste helps to NOT allow micro leaks.
Edited my original post.
Honestly didn't mean to. ,!
They are too close together
Reply to Thoughts on jointing compound for compression fittings? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
