Discuss Thread Views, Thread Subscriptions etc etc .. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
These are all sorted now...
.. all threads will update and those who use thread subscriptions will now get emailed..
- Status
Reply to Thread Views, Thread Subscriptions etc etc .. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I thought I'd create a master thread to move all of these similar threads into, over time like.
If your central heating doesn't work
boiler doesn't work
radiators not working
radiators or heating system is cold
thermostat wont work or respond
Then post a reply in this thread. Rather than us...
Morning all. I hope this is the correct place for this post. If not i'll happily move it to another forum area.
I am renovating a property and the old cast iron radiators need a refresh, and i'm going to fit some new bleed valves amongst other things. The female thread in most of the rads...
I have a garden setup with metal pipe at each end and a pvc run in the middle. Proposed. That's what i want to do. Join the two with water pressure 1/2" pvc. So the gear is all there. Threaded joiner at each end. Elbows and joiners making the run between.
But I realise if the threaded ends...
Hello All,
I know that this is a question for a Forum Moderator and probably should be posted in a section about the Forum itself but I was hoping to get some replies from Members about whether this is happening to anyone else:
When I logged into the Forum this afternoon and went to look down...
Our House is now fully Heat Pumped, insulated and we have had the Gas Meter Removed.
We have a 1950s foldaway Cannon Gas Grill which is on the wall above the AEG Induction hob with 1 Gas burner. It worked very well on Natural gas. We have had the local gas co. install an LPG supply using...
