Discuss Threads: 6,114, Posts: 33,682, Members: 6,814 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dan
Administrator
Staff member
Admin
I've cleared up old unused accounts so we've drop about 1200 members. Though at least we know who's active now. :)
Still good getting over 6,800 that are active though. Some of those being new and not posted yet but all the rest have posted. :)
Well done to you all.
Reply to Threads: 6,114, Posts: 33,682, Members: 6,814 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In short: Do suppliers sometimes list BSPT as BSP? I need a tee, 22mm each end with a BSPT in the middle for an expansion vessel to dangle from. Why I think its I've used calipers on the threads and counted them, and the male end sticking out of the vessel is BSPT 3/4 with 14 threads per inch...
I removed an old shower hose, which was installed by previous home owner at least 12 years ago. Upon removal, the connection is like nothing I have ever seen and I am unable to find any replacement hose of similar connector type. btw: When I removed the hose , there was no loose rubber washer...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Hi All, I have recently changed heating source to a heat pump and so I have had a new water cylinder installed (different internal element required). This means that I have a 2.5 year old StainlessLITE Plus Horizontal unvented mains pressure 204L cylinder left over. We had it installed in Jan...
Peter M
    • Optimistic
Hello All, I know that this is a question for a Forum Moderator and probably should be posted in a section about the Forum itself but I was hoping to get some replies from Members about whether this is happening to anyone else: When I logged into the Forum this afternoon and went to look down...
